It is currently Fri Aug 15, 2025 2:12 am
PostPosted: Mon Sep 09, 2013 10:33 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Finally building a 2 ft high by 2ft by 2.5 ft go-bar deck , does anyone have a good inexpensive source for the fiberglass dowels ?? thanks
PostPosted: Mon Sep 09, 2013 10:42 am
First name: Rusty
I got mine from Max-Gain, a fiberglass antenna parts supplier.
http://www.mgs4u.com/index.html
Another source is kite supply companies.
PostPosted: Mon Sep 09, 2013 10:46 am
Into the Wind is a good source.
PostPosted: Mon Sep 09, 2013 11:27 am
I use the fiberglas driveway markers from Lowes.
PostPosted: Mon Sep 09, 2013 11:39 am
First name: Miguel
Last Name: Bernardo
Country: portugal
i
PostPosted: Mon Sep 09, 2013 11:40 am
First name: Miguel
Last Name: Bernardo
Country: portugal
i used goodwinds, per Todd Stock“s suggestion. good service.
PostPosted: Mon Sep 09, 2013 12:36 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks todd, gud idea there/s only 2 loofiers on forum in the metro area dennis k an aaron lives abt 40 mo away in a far n. burb,inless there/s others .I will check out goodwind. I have a 4in diamond blade on angle grinder .will that cut the Fiberglass rods cleanly? I have not cut fiberglass before.
PostPosted: Mon Sep 09, 2013 6:38 pm
I know you asked about fiberglass specifically, but the 5/16" poplar dowel from Lowes is $.88 for a 48" length. Cut them in half and that works out to $.44 each. Don't waste your money on the oak dowels. They break way too easily.
I use the dowels because I like to cut a concave section out about 6" long from the the top half of the dowel. I go about 1/4 way thru the dowel at the deepest point of the cut out. This makes the dowel flex only at the top, and is easier to keep the bottom part of the dowel pressing straight down on the brace or part that you are clamping.
James
PostPosted: Mon Sep 09, 2013 7:42 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks for the tip james .I was going to lowes tomorrow morning to pick up the black pipe for the supports. I can pick up some driveway fb markers and try them as well as the dowels .I/ve got some dowels in the bsmt. to check out.
PostPosted: Mon Sep 09, 2013 9:17 pm
First name: William
Last Name: Stewart
City: West Chazy
State: New York
Zip/Postal Code: 12992
Just found the fiberglass driveway markers at the local dollar store, for a buck ea. 48" , cut with old fine toothed bandsaw blade, high speed grinder, angle drive grinder, hack saw. Wrap a couple of layers of masking tape first to prevent splintering. Don't use good blade, or it will instantly be toast......
PostPosted: Mon Sep 09, 2013 9:34 pm
I use a hacksaw and a fine file to chamfer the ends. The masking tape is a good idea.
PostPosted: Mon Sep 09, 2013 10:51 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
http://www.bluescreekguitars.com/shop/i ... 20a&page=2
PostPosted: Mon Sep 09, 2013 10:53 pm
First name: Rienk
Last Name: Ayers
City: Santa Maria
I'm building my go-bar deck into my workbench (someday). Because I'm tall and don't want to hit my head on the top plate, I will need much longer rods to fill the space - which means they also need to be larger diameter to exert the same amount of pressure.
Keep that in mind if you want to also have a taller space between decks.
PostPosted: Tue Sep 10, 2013 10:40 am
Last Name: Lee
Country: Wales U.K.
Fibreglass rods are used in making Roman blinds and I have found they are a lot cheaper than other sources such as kite making supplies.
eBay UK has a lot on offer.
PostPosted: Tue Sep 10, 2013 11:52 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Went to lowes checked out the poplar 5/16in dowel seems weak and not much able to bend .The driveway fb marker seems much stronger, bends readily, and will last forever.
PostPosted: Sat Jan 10, 2015 3:25 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Just picked up 2 dozen fiberglass rods to use as go-bars from the local Dollar store. They were selling them for $1 as driveway markers. You have to live in a snow zone to understand what this is for. I got a few strange looks from people with my armload on the way out...thinking my driveway must be huge.
Doug
These users thanked the author Doug Balzer for the post: Robbie_McD (Sat Jan 10, 2015 7:16 pm)
PostPosted: Sun Jan 11, 2015 12:37 am
Last Name: Shanklin
City: Windsor
State: ON
Goodwind Kites is great if you are in the States. They have the rubber tips as well. Shipping is murder to Canada. DAMHIKT
Bob
PostPosted: Sun Jan 11, 2015 10:53 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I cut mine with a Dremel using a cut off wheel. Wear a dust respirator and be careful that it doesn't bind when you're about to go through.
Kevin Looker
I'm not a luthier.
PostPosted: Sun Jan 11, 2015 12:32 pm
I like using spring tension curtain rods. You can adjust them to your desired length and tension for different size object being glued, they have rubber ends which are easy on the wood and since they compress, not bend, it's easy to set them up pressing straight down on the the piece you are gluing.
PostPosted: Sun Jan 11, 2015 12:49 pm
I used Into the Wind when I was re-tooling 8 years ago. Couldn't be happier. 3/16" rod with rubber end caps.
PostPosted: Mon Jan 12, 2015 9:03 am
First name: Al
Last Name: Peebels
City: Johnston City
State: Il
Zip/Postal Code: 62951
I found driveway markers to be way too stiff when cut to 2 feet, longer woks fine. I'm using wood yardsticks from Home Depot. I rip them down the center then cut them to length. These work fine at 2 feet long.
PostPosted: Mon Jan 12, 2015 10:26 am
Into the Wind is where I got mine about 7 yrs ago. Get extra rubber caps as I've had 2 or 3 split over time.
Users browsing this forum: Colin North and 17 guests
